Sub Panel not working in Exe file
Since you are dynamically loading VIs, they are not automatically included in the executable. After all, you're just providing strings.
Even though you're providing paths, the exe might very well not be able to load them. The VIs might depend on vilib items that are not available in the executable. Or the VIs don't have compiled code (if separate compile code is on).
I'd recommend using static VI references instead. There's no need at all for strings. They can introduce typos and problems like you have atm.
Alternatively, if you really, really want to use strings, add the VIs to the always include list of the build.
Message 11 of 18
(1,479 Views)
HI SIR
HERE IS MY MAIN VI
Message 12 of 18
(1,476 Views)
Hi kps,
finally you attached some code, thanks!
What about that "there are no errors" observation?
You are deleting/clearing all error messages within your DynamicLaunch subVI!
(I cleaned up that subVI a little bit. There's no need to maximize frontpanel AND blockdiagram to full screen!)
So: implement a better error handling and logging to recognize/analyze such problems much easier…
Message 13 of 18
(1,459 Views)
Hi Sir
I removed those error clear pallet and tried again but now also the sub panel vi are not executing
it just display the front panel in sub panel
that vi not executing
Message 14 of 18
(1,453 Views)
But now you should get some useful error messages in the error wire…
Message 15 of 18
(1,451 Views)
No error is coming
Message 16 of 18
(1,454 Views)
@kps001 wrote:
Hi Sir
So you removed the clear error... Hope the error is rewired?
Without updated code it's hard to tell.
Have you replaced the strings with static VI references?
Have you added the VI to always include list?
Without something we can actually compile, we can't really tell.
Message 17 of 18
(1,441 Views)
@kps001 wrote:
No error is coming
Errors are not "coming" automatically. Even if you enable automatic error handling, if the error is wired to a structure, I don't think you'll get an error.
You'll have to wire a simple error dialog to all end points of errors, or put all errors on the FP. Otherwise you might not notice the errors at all.
Message 18 of 18
(1,438 Views)
