Sub-VI connections not shown
I have 2 little problems:
1. I made a sub-VI, but when I import it into another VI, the connection-pins arent visable. What did I forget?
2. every time I re-open my VI, I lose parameters that I typed into a string. How can I arrange it, that I fe. store them in a local variable, and won't lose them when I shut down my PC.
(2,905 Views)
1. From the front panel of your subVI popup on the icon and select Show Connector. Then click on the connector panes and the controls/indicators to connect them. Save the subVI again.
2. To change the default values set the values as you wish them to be. Go to menu Operate >> Make Current Values Default. Save the VI. If you want to save values that a user entered at runtime, write the data to a file. When the program starts, read the file and use property nodes or local variables to set the controls/indicators to the saved values.
Lynn
(2,892 Views)
1. Did you define the pin connections in the connector pane of the sub vi?
2. Whenever you want to save an entry in a control, you must right click on the control and select Data Operations - Make Current Value Default. Save the vi. The next time you open it, the default value should be there.
- tbob
Inventor of the WORM Global
(2,891 Views)
Good Day Kuvak,
Hope this might help 😃
Daniel
(2,868 Views)
I was on holiday so I`ll try this methods next Monday.
thanks a lot!
(2,843 Views)
