Sub VI only works if nothing in call chain is a dialog.
Open Main.vi and run it.  It works OK.
Open its VI Properties and change its window appearance to "Dialog".
Now it won't work.
(1,470 Views)
Being modal causes the problem.
(1,464 Views)
Could it be the "Interactive" node on your "Open LV Document" script call in "Get all errors" sub-VI?  The Help says if this is True, "LabVIEW may display dialog boxes ..."
Bob Schor
(1,449 Views)
It's actually the 2nd invoke node: "GetActiveVIRef".  I want to get a reference to the VI just opened, but if something is modal or floating, the Active VI ref isn't to the VI just opened.
(1,407 Views)
I'm guessing a modal window is always active, so either use some other tag than active, or temporarily unset the modal flag.
Qestit Systems
Certified-LabVIEW-Developer
(1,375 Views)
I ended up having to cheat by snatching the contents of "Error Ring.xnode:Get All Errors In Family.vi" (if course what I had been trying to do was also cheating).
(1,358 Views)
