Sub VI to export in excel work randomly
Dear Friends,
I use following SUB-Vi to export an array to excel and it works randomly, and I have no idea how to fix this problem.
Any help or tips from your side is highly appreciated.
The path generates in another sub_vi
(3,003 Views)
@arvin1947 wrote:
Dear Friends,
Tell us more about when it does not work.
Ben
(2,995 Views)
Since your array is an array of "Numerisch" I assume we are looking at a German version of something.  Darn those Germans use a "," Radix seperator.  Of corse that would be a moot point if you used "Format (Hex|Dec|Oct|Bin) Integer number to string" and didn't force all thouse I64s to end in "(.|,)000000" (6 zeros after the selected LabVIEW radix seperator, either period or comma depending on the ini file)
Let's fix that first and then see what else may be wrong OK?
(2,977 Views)
Dear Ben,
this exactly drives me crazy, I have no idea why it works randomly, sometimes It doesn't work and I have to open excel file and it works after that.
I highly appreciate  your help
(2,966 Views)
Is this subVI called repetively in a loop? If so what is the approximate delay between subVI calls? Is there an error generated?
Ben64
(2,944 Views)
