Sub VI would consume less memory??
I read a book today. It said using subVI can save the memory usage. Is that true? How to achieve that? I don't quite understand
(3,603 Views)
One reason.  If you have a section of code that is repeated, it is stored in one subVI rather than copied all over the place in the main VI.
(3,601 Views)
I see. Thank you very much!
(3,551 Views)
Please note that subVI use can increase memory, as well.  If the overhead of calling the subVI is more than the size of the code in the subVI, you will actually increase the size and load time of your code.  The breakpoint is about 16kbytes code and data for the subVI (assumes block diagrams and front panels are removed).
(3,529 Views)
