Sub VI
If I use a SubVI in multiple loop at the same time, would my application create an image of the same Sub VI in 4 different places and execute the code or does it share the same Sub VI one after the other?
thanks,
Mudda.
(2,968 Views)
if you did NOT check "re-entrant" it will share one instance.
Ben
(2,964 Views)
thanks
(2,961 Views)
