Sub-Vis in Web Publishing Tool
Hi!
I try to start a Sub-Vi from the main Vi published via Web Publishing Tool. My Problem is, that the Sub-Vis does not start in the same html-Page. Is it possible to start a Sub-Vi in the same frame the main Vi was before (Main Vi closes by starting Sub-Vi)?
Thanks for helping!
(2,507 Views)
I create an example, I hope this can helps you.
Best regards
Marko
(2,476 Views)
