Sub Windows
I would like to know if by changing some settings in File --> VI Properties --> Execution --> ??
i could possibly have two windows that function simultaneously, i.e., the 'Caller' Screen and the 'Called' screen both are showing values from teh PLC in real-time ??
(2,816 Views)
Running VIs sumultaniously and parallel are a matter of programming and not of properties.
You can run two VIs in parallel if you put them in parallel loops or you load them with the "Open VI Reference" and start them with the "Run VI" Method. This is the same as loading with File>Open and then click the run button.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,816 Views)
