Sub vi input for dynamic data type
i am trying to create a sub vi that acquires dynamic data input ( as in simulate signal)
. PFA the vi i have created so far
How do I give an input terminal for Dynamic Data Type? I want to be able to acquire and process a simulated signal to start with !
thanks
ps I'm using LabView 8.5
(7,847 Views)
I am not sure whether i understood your problem well or not. But if you jsut need some simulation values to work with, you may either use a simulate signal express vi or simply use a random number generator form the arithematic function pallette.. If you can explain a bit more, may be i can get you a better solution.:)
Nitzz
(Give Kudos to good Answers and Mark it as a Solutoin if your problem is Solved:smileywink:
(7,846 Views)
We are trying to create a VI that can be used as a subVI in another program.
In the new program, where I am using my self-created subVI, I want an input terminal that can be efficiently wired to a Simulate Signal VI. That is, I want a dark blue lined input terminal.
How do I create such an input terminal in my VI ? We created input terminals for all other parameters, but we are unable to create a terminal for input data.
Dheeraj Bharadwaj
IIT-Madras
(7,843 Views)
Hi Dheeraj and Avinash,
I got your point. For creating such an input you make a graph indicator from the simulate signal, then change it to a control, put this control into your subVI, and wire this graph control to your connector pane and save the VI. Now if you use this subVI in any other VI you will have a Blue color input terminal.
Nitzz
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
(7,839 Views)
Thank you for the tip, this solved the same problem for me.
p.s. that answer should be marked as the solution, so it is visible that the problem is solved
Vladimir
(7,675 Views)
Hi NitzZ,
Thanks alot for your explanation,it also helped me to solve a problem i had been trying do so for some time.
This should be marked as solution of the problem
DANIEL KETUI
(6,892 Views)
