SubVI: Access IOs and Frontpanel
I have a problem accessing the io-interface (Input and Output on the
Symbol) and the frontpanel. I have a main-vi which loads other sub-vi's
and displays there frontpanel in a tab-widget ("registerkarte" in
german)and i also have to connect there ios.
can anybody give me a help how to handle this.
Max
(2,493 Views)
I'm not sure exactly what your problem is. Can you not wire front panel controls and indicators to subVIs or is it something else? Further explanation would be helpful and if you could attach the main VI and subVIs that would help too. To save everything to a single file, select Save With Options and choose Development Distribution.
(2,493 Views)
