SubVI DAQ Assistant
Hi Mangesh,
I have installed the drivers. I'm using : NI-DAQmx, version 9.3.
Anything else I missed?
Message 11 of 23
(3,087 Views)
Varsha,
It seems that the DAQmx is not responding either due to it gets corrupted or not installed properly.
If possible try to uninstall and reinstall DAQmx drivers
Also make sure that beside DAQ Assistant other DAQmx VIs are working properly or not.
Message 12 of 23
(3,076 Views)
I have already re-install  my 3rd attempt.
Other DAQmx VIs are working.
Are u getting the same error as mine when you run the file? Could you help clarify please?
 Thanks.
Message 13 of 23
(3,068 Views)
If the other DAQmx Vi's work why don't you rewrite it?
I mean the assistant is just a start up. It's slower then when you build it yourself.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 14 of 23
(3,066 Views)
Sorry, I typed too fast and hit Post. Other DAQmx Vi's are not working too.. I cant seem to find the DAQ control Task.vi. Its missing.
I dont know what else to do. Could you help advise?
Message 15 of 23
(3,062 Views)
Your DAQ assistant opened just fine for me.  (It is set for Dev1/ai0, continuous voltage acquisition, 200 samples at a 1 kHz rate).
I still think it is an issue with your DAQ drivers.
DAQmx 9.3 is the newest version that still works with LabVIEW 8.5, which is the version that your VI says it is.
Yet in an earlier message you say you are using LabVIEW 2011.    LabVIEW version needs DAQmx 9.3.5
See NI-DAQ and LabVIEW Version Compatibility (for Windows)
The latest version of DAQmx is 9.8, and the chart shows that it still works with LabVIEW 2011.
I recommend you install the correct version of NI-DAQmx that works with your version of LabVIEW.
Message 16 of 23
(3,054 Views)
I cant seem to find the DAQmx .vi files. I browsed here:http://www.ni.com/white-paper/2744/en#toc1
but I dont see the DAQ Assistant in my case as below:
Message 17 of 23
(3,051 Views)
In message 6, you said "I have also placed a new DAQ but same error appears."
How were you able to place a new DAQ assistant if you don't have it in your palettes?
Like I said, because DAQmx 9.3 is not compatible with LabVIEW 2011.
Install the latest version of DAQmx.  Then the DAQmx functions including the DAQ Assistant should show up in your LV11 palettes and the code should start working.
Message 18 of 23
(3,047 Views)
Yep, you need at least version 9.3.5 to use DAQmx with LabVIEW 2011.  See here for more details:DAQ and LabVIEW Compatibility
Message 19 of 23
(3,042 Views)
Varsha,
My DAQmx working Fine.Your code is also not having issue in my labview
Here we try to figure out what exactly the problem is. It doesn't mean that whatever we''ll tell always works since there might be some issues which are related to Installation or OS .
As per your information it is clear that your DAQmx(it does not relate to only DAQ ASSISTANT) is not working in Laview 2011.
So I exactly don't understand the issue.This might related to Licensing (weird but might be)
Have you installed the drivers by disabling the antivirus protection?
Message 20 of 23
(3,034 Views)
