SubVI is not executable
How to fix that ?? help me please.
(3,599 Views)
That really is not much information to go on, there are a ton of things that can make it so a VI is not executable. When you click "show error" I assume it takes you to the express VI of the second screenshot?
A target is any machine that will run the code, in this case it looks like a myRIO device. It appears your myRIO device does not support that I2C express VI.
(3,584 Views)
Hello Navarro114,
I suspect that you have this VI below My Computer on your project and probably trying to use the I2C Express VI for myRIO.
Just make sure where the VI you are working on is under myRIO and you should be able to use this Express VI.
PedroR
(3,526 Views)
(3,522 Views)
