SubVI with Cluster
Hi
I want to pass Cluster to SubVI.
Could anybody tell me how to make SubVI know Cluster data without create any cluster in SubVI?
Thank you in advance.
(3,596 Views)
Hi MS_CJ,
you can pass a reference of the cluster to your subvi. Or you use a variant. Why don´t you want to create a cluster in the sub vi?
Mike
(3,589 Views)
Hi Mike,
I want to use this SubVI as function which can receive any cluster.
if I have already created some Cluster in SubVI then it doesn't work when I try to pass another type of Cluster into such SubVI.
Your guidance seems that can only use with same type of Cluster. Right?
(3,586 Views)
Hi MS_CJ,
use a "cluster" reference and not a special type, then you can pass all clusters to your subvi.
Mike
(3,583 Views)
Hi Mike,
Thank you for your guidance.
(3,543 Views)
