SubVI with void array input and output
I want to create a SubVI that has a 1D array of any type as input and produces a 2D array of any type as output. When I try to do this I get an error about connecting different data types. It would be very elegant if my SubVI could work for any data type because it only rearranges the array elements in a certain way.
Thank you.
Message Edited by mrsound on 11-18-2009 04:20 PM
(4,196 Views)
You could make a polymorphic subVI. Check the help.
(4,179 Views)
Ok, thank you.
(4,164 Views)
