SubVi does not work
Hi there,
I put a SubVi in my main program but it does not return data. I mean that there's a flow of data entering the SubVi
but it returns only costants.
The SubVi convert bin data from NI 9203 cRIO AI module to pressure units
The SubVi always worked properly on an application already developed in LabView 8.0
now I am trying to develop a similar application in LabView 8.6 and using old SubVi.
I tried to connect again terminal in the subVi and save it, but it did not work.
It works only if I rebuild the SubVi entirely from the start.
So I did it but now I have to put 2 more SubVi and the problem is the same.
Maybe it's just an easy problem to solve but I can't work it out
thanks.
(3,022 Views)
We can only help you if you provide us with the code - it's quite impossible to know what your difficulty is from your description only.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(2,996 Views)
