Subpanels and popup question (labview 7.0)
I had popups before to ask the user to input values, when I click on ENTER (key) the popup closes.
Once put the popup into the subpanels (to get rid of many popups), when I enter the values, ENTERED. the screen doesn't closes and move on.
It makes me grab the mouse and click on OK in order to move on.
Is there a way to fix that? thanks for your help
Krispiekream
Message 1 of 25
(4,510 Views)
Krispiekream
Message 2 of 25
(4,495 Views)
I'm not sure if this works in LabVIEW 7.0. Right click your "OK" button and see if the Toggle is set to Return.
Message 3 of 25
(4,493 Views)
here are the vis
Krispiekream
Message 4 of 25
(4,486 Views)
Krispiekream
Message 5 of 25
(4,484 Views)
how do you select KEY ENTER?
Krispiekream
Message 6 of 25
(4,477 Views)
@krispiekream wrote:
here are the vis
In your "MSG with number_new.vi", hitting the ENTER key on the keyboard works fine on my system. But I am using LabVIEW 2017.
Message 7 of 25
(4,474 Views)
maybe because its not in a subpanel?
can you put it in a subpanel and see if its still okay. its not okay on my end
Krispiekream
Message 8 of 25
(4,466 Views)
Are you sure the OK button is not working? It may be working correctly, but the window is just NOT automatically closing afterwards. Try checking this setting. Show "VI Properties->Window Appearance"
Message 9 of 25
(4,451 Views)
Krispiekream
Message 10 of 25
(4,424 Views)
