Subpanels architecture
I´m programming an application using subpanels architecture and I am finding the following problem: The VI's loaded and run work well The first time I call them but the next times I try to run them, the error screen appears saying that they are not in a compatible state with that action. I think this has to do with the fact that I am not using the correct method to finish their execution.
Anything you could tell me would be very hepful.
Thank you so much.
(2,958 Views)
If you can include your code that would help us determine the problem. If not the actual code an example that behaves the same (a simplified calling vi and sub-panel one)
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,939 Views)
