Subroutine inside a StateMachine ?
While coding StateMachines I often find a need to execute a particular set of states more often. And the easy way to do this is to just dplicate the required states to fall in line.
I  was wondering if this can be done like a Sub-routine call in a text based language : The enclosed VI ( broken though ) shows my requirement.
- I have main states from "Intialize"  to "EndState".  And  "subroutine"  states  from "Sub_A_Start"  to  "Sub_A_End".
- From State_02,  I want to jump to Sub_A_Start. Before I jump there, I also save the return point ( State_03) in a functional Global.
- From the last state Sub_A_End, I would like to come back to State_03 and continue  the main. For this if I use the functional global and wire it to the StateCase SR, the  enumeration  of the SM is lost and  replaced by simple numbers.
While I can understand why this happens, I would like to know if there is way to pass enumeration data via  Functional Globals ?
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(3,172 Views)
Make it a Type Def and use it everywhere that you refer to the states.
André
André (CLA, CLED)
(3,159 Views)
The State Cases are already contained in a Type Def enumeration.
But what I want to do is pass this Enumeration data type through a functional Global !
Is THAT possible ?
thanks
Raghunathan
Raghunathan
(3,120 Views)
Is THAT possible ?
Yes It is possible Smiley Very Happy The code as I wanted is attached.
thanks for your help.
Raghunathan
Raghunathan
(3,112 Views)
