Subsystem Output not updating
I have some matlab code that sends a random number (-1 or 1) to labview. I currently have a labview VI that reads this number and shows it on the front panel. Let me call this 'subsys1' and 'output1'.
I have another labview VI, let's call it 'V1'. In 'V1' I have my subsystem 'subsys1' with 'output1' that connects to a numeric indicator on the front panel. When I run 'subsys1' on it's own, I read -1/1(constantly updating) in the numeric indicator on the front panel. When I run 'V1', I read '0' for 'output1'. However, when I look at 'subsys1' in the background(while 'V1' is running), I see -1 and 1 on the numeric indicator.
I would appreciate any suggestions for what the problem could be. Thank you.
(1,221 Views)
It is quite hard to comprehend your text descriptions. Could you please attach the VIs and MATLAB code that you're describing and some GIF/image of the issue?
Santhosh
Soliton Technologies
(1,206 Views)
To recreate my problem, run 'main_minimal_V0.m' in matlab. This code sends 2 numbers from matlab to labview(if I can change it to 1 that would be great, but I'm not sure how) and also receives 3 numbers from labview. 'exchangeData.m' should be saved in the same folder. In labview, run 'mainVi.vi'.
If you have 'exchangeData.vi' open at the same time, you'll see that either -1 or 1 appears in the 'string from matlab' indicator on the front panel(in exchangeData.vi). However, in the 'mainVi.vi' front panel, the numeric indicator is 0.
I want the indicator on the mainVi.vi front panel to be 0.
I am having issues attaching 'exchangeData.m', I have tried renaming it and uploading it as a txt instead but to no success. I will try to edit this post.
(1,182 Views)
