Subtract 2D array elements and insert the result into a new row
I need to subtract two consecutive elements of multiple rows in 2D array and assign them to a new row. Attached file the previous question.
(3,127 Views)
Here is a simple representation of an example of how to subtract two consecutive values in a row and then add all the values to a new row. This sample only subtracts the same two values per row. If multiple subtractions per row are needed than another For Loop internally would be needed.
(3,117 Views)
Thank you, i will test your solution
(3,110 Views)
