Subwindow Creation
Hai Everyone
              I have an one doubt in LabVIEW .If its possible to create the Window in LabVIEW.Below i attached one screenshot .I was taken from the NI TESTSTAND.In Teststand there is an one window called as Step settings Window.Like wise the window I Wants to create in LabVIEW and the controls are as LabVIEW controls.If i want to close that Window it close and the above window should Maximise and If i Press the VIEW option in the Menu bar and select the Name of the window it will shows the window.
Jayavel
(2,901 Views)
Jayavel,
 Your question is a unclear due to a language barrier. LabVIEW VI's (Virtual Instrument) consist of a front panel and a block diagram. When you insert a VI into TestStand there will be a checkbox selection "Show VI Front Panel When Called" option. If this is checked and you run the sequence the VI's front panel will appear.
  If you have the LabVIEW development environment with your TestStand environment you will also have the abililty to edit and create LabVIEW VI's within the TestStand environment. Here is a good reference.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,869 Views)
