Suddenly Error -17306 in LV-Operator-Interface after 3 hours when trying to read a StationGlobal
i´m using the example-labview-operator-interface with some modifications.
One of the changes is that i created a Thread (UserEcentCallback.vi) which reads a value from the StationGlobals and displays it on the OP.
This thread is running in a loop and executed every second. This worked fine for ~ 3hours and suddenly the attached error-message appeared.
What can i do to prevent this problem?
I´m using the default "TestStand Get Property Value.vi" to read the Globals.
Thanks for all tips.
(Sorry for double posting, buut i dont know if this is a labview or teststand-problem)
Message 1 of 1
(2,365 Views)
