Suggest analog output card
I need to generate below parameters with the help of Labview
Passive tachometer input:
Operating Frequency Range 5Hz to 2000Hz
Sensitivity: 250mV p-p
Safe operating range: 0-100Vp-p
Input impedance: 8k Ohms
Accuracy: 0.1%
Active tachometer input:
Operating Frequency Range 0Hz to 2000Hz
Sensitivity: 7V
Safe operating range: 0-15V
Input impedance: 860 Ohms
Accuracy: 0.1%
Please suggest an appropriate analog output card?
Prashant
(2,428 Views)
Hi UPRR,
Are you looking for any particular form factor? Do you prefer to have a module that solely does analog output? The NI 9263 and 9264 are two AO modules that can output -10 to 10 V and should meet the requirements you have posted. There are many other options we offer as far as cards and modules that support analog output and choosing among them depends on whether you want any other functionality from the device and/or the form factor you would like to have (PCI, USB, PXI etc).
I hope this helps.
James D.
(2,406 Views)
Frankly, I would stongly recommend picking up a phone and contacting your local NI sales rep. You're going to need to provide far more deails than what you've done, and a forum simply isn't the best way to do this.
(2,394 Views)
