Suggestion for an compressed air pressure sensor
Hope you are doing well. I have a pneumatic chamber(Air pressure :50-150psi). Now I want to measure pressure of the chamber using a gauge. Additionally, I want to get the data from gauge through a daq(NI USB 6212) or serial communication.
However, I am unsure which sensor/gauge/device to buy. I found one analog pressure sensor(https://www.revrobotics.com/rev-11-1107/). Could you please check if this one would fit in my application.
I will also appreciate if you can suggest something with digital display.
Best,
Jarir
(848 Views)
Accepted by topic author Jarir
The sensor you have have suggested will be adequate for your application.
All you will need to do is write the code to read the voltage output signal.
(813 Views)
Update: It's working fine.
Do you have any suggestion for good and reliable positional/IR sensor that works with USB DAQ 6212?
(748 Views)
