Suggestions for the Best Tool to Make a Quickie Wrapper DLL for Callbacks?
I've got some API callbacks for which I need to make small wrapper functions and bundle them into a DLL.  The structures are too complex for the LabView App-builder to deal with in generating the DLL.
Any suggestions for a quick/easy/free/cheap tool to build this DLL? I've got the C-code - just need to compile it into a DLL for the windoze environment.
Thanks!
(3,637 Views)
Hi Wiredup,
      I think MSVC++ Express (free from MS) will do it.  When creating a project it won't show a DLL option, but once project is created, change Project\Properties\General\Project Defaults\Configuration-Type to DLL.
Cheers!
Message Edited by tbd on 02-25-2008 11:39 PM
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,623 Views)
Or you can use the nmake tool and the compiler that comes with the Express Edition from the command line. I really hated that IDE, so I have my own editor and just typed a makefile that I process with nmake from the shell.
This makefile should work for you (I build my DLL with a similar one)
# Links the DLL
mylib: *.obj
    link /DLL /DEF:module_definition_file /OUT:mylib.dll *.obj
# Compiles all the sources into object files
%.obj: %.c
    cl /c %.cpp
I'm not sure if LabView needs the module definition file or not, but you can try without it first.
When you have the IDE installed, you need to execute a batch file called vsvars.bat in order to use the linker and compiler from the command line. This batch should be found from directory ...\VC++_install_dir\Common7\Tools
If you have any questions about this procedure, don't hesitate to ask.
Hopefully this helps.
Message Edited by kaêm on 02-26-2008 08:58 AM
(3,615 Views)
Thank you kindly for your swift replies. I've ventured into MS Visual C# land to begin this work (trying to avoid too much baggage associated with C++ decorations, etc.). I think I'm about there. I am struggling with one aspect of this wrapper, though:
I need the wrapper to present the proper data types to the caller of the callback. However, once I've generated/converted the supplied data to data types that LabVIEW understands, I need to generate a UserEvent (the data is passed as a flattened string to the UserEvent). When I was using the App Builder to make the callback, this was not a problem. Now, I'm lost as to how to generate a LabVIEW UserEvent from within a C# or C++ environment?  I'll start surfing the boards and see what I can find.
Thanks again for your help.
(3,601 Views)
Hi Wiredup,
These links may help:
Using Callback Functions to Respond to User Interface Events
http://zone.ni.com/reference/en-XX/help/370051K-01/cvi/cviusing_callback_functions_to_resp/
Responding to Keypress Events on a Control
http://zone.ni.com/devzone/cda/epd/p/id/1979
Recognizing Events Passed from the User Interface to the Program
http://zone.ni.com/devzone/cda/epd/p/id/1871
(3,559 Views)
Thank you. I had not seen that first reference link. It is very helpful.
I'm finding the easiest way to implement this wrapper is to write a C function that is exactly formatted to the structures specified by the API's callback. These functions simply call functions re-format the data into atomic/flattened/byte array structures that the LabVIEW can understand. Once reformatted, a second callback function is called that contains LabVIEW-generated code (like a user-event firing based when data is received). I'm simply using the App. Builder to make this second DLL.
In other words, when the API calls a callback function, the following data flow occurs:
API Function -->>
 C-authored callback function -->> LabVIEW AppBuilder Generated Function  -->> User Event with Flattened String containing data.
Not pretty, but it seems to work!
(3,528 Views)
