Sum formula node
Hey There
I'm new to Labview and need some help. I want to make a surface interpolation and use "3D p fit" for this.
Afterwards I want to calculate the values and show them to see how good the approx is. I use a formula node for this because I want to chose the order of polynome approx.
In here
z : output
x,y : coordinates in Array
xi,yi : index for coordinates (Where we are...)
n : Order of polynome
int i,j,ci;
z=c[0];
ci=0;
for (i=1; i<=n; i++)
ci=ci+i;
z=z+Sum[j=0 -> i] (c[ci+j]*(x[xi]**j)*(y[yj]**(i-j));
The problem is that it always tells me that there's an error with the sum and since I can't figure it out I hope you might have some infos.
Hope that it is clear what I tried to describe
Thx Hans1
(5,377 Views)
Can you post the Block diagram you made for this problem...
Smiley Wink
(5,368 Views)
Accepted by topic author Hans1
Hey
I did a little work around by using a second for loop instead of the Sum. But if anybody has the same prob. that's how I solved it:
22777iC79EC565F4FBAE2D
(5,361 Views)
