Superimpose two signals in one period
I am trying to superimpose two different waveforms over one period (0<t<T).
Consider that
The first waveform which is x1 = sin(wt), would be valid for 0 <= t <= T/2.
The second waveform which is x2 = square(wt), would be valid for T/2 <= t <= T.
So, in a way, I need to cut the first signal until T/2 and begin the second one from T/2 until T.
I know there is a similar post here: https://forums.ni.com/t5/LabVIEW/Chopping-a-waveform-for-half-cycle-for-higher-frequencies/td-p/3896....
However, superimposing the second signal does not exist.
I would appreciate it if someone could provide me with an answer.
Thanks in advance
(1,323 Views)
Accepted by topic author EliioF
Have you looked at the Waveform functions (found, it turns out, on the "Waveform" Palette)?  You can use them to do the following:
  • Generate the first Waveform (look under "Analog Waveforms" and then "Generation").  Figure out what parameters you need to get the points you need for the first half.
  • Generate the second Waveform using the same procedure, changing the parameters to suit the second half.  Note that if you want the waveforms to be "continuous" at their join, you'll need to do some computations (or look at the data points) and specify a starting Phase for the second waveform.
  • Now use the Append function to join these two Waveforms together.
Bob Schor
(1,272 Views)
Hello Bob
Thank you for this insight. What I did was multiply each waveform by a corresponding square function for half the period.
However, I did notice some "discontinuities" around zero. So since you mentioned "Note that if you want the waveforms to be "continuous" at their join", I will try playing with the phase of the second waveform, then use the append function to join the two together.
I am commenting on my case maybe someone might have a similar issue. Thank you for your help.
Elio
(1,260 Views)
