Support Xnet in Veristand
Once done with the modification, you can rebuild the Configuration Release and Engine Release.
The build specifications are configured with Post-Build VI to copy the built files to the Public Documents directory. Your custom device will be overwritten by the modified version. You can proceed to configure it as usual.
https://tmesystems.net/
Message 11 of 15
(357 Views)
Hi
 I Opened this project but I saw it is missing many vi as below image:
 I think this reason I can not build this project
 Do you know how to fix this issue?
 Thanks for support.
Message 12 of 15
(343 Views)
As I have mentioned earlier, you need to install all the dependencies.
Message 13 of 15
(331 Views)
Hi ,
Sorry to bother you, do you have the file of the image below for labview 2020?
Message 14 of 15
(225 Views)
Use git to clone the entire repo and start from there.
If you are not familiar with git, there are many free tutorial online.
Message 15 of 15
(220 Views)
