Support for Pioneer P3DX
Is there support for MobileRobots Pioneer 3-DX (P3DX) Differential Drive Robot in Labview? http://www.ni.com/white-paper/9079/en#toc4
any example code i could look at?
(3,058 Views)
Looking into how the P3DX works, there is an API that you can call through a Call Library Function Node.  However, National Instruments does not have any direct examples for the P3DX in our robotics module.  A few third-party resources on how to actually manipulate the robot using LabVIEW can be seen below:
http://www.chiefdelphi.com/forums/archive/index.php/t-93880.html
I suggest using the link on that forum for a bit more information on how you can use the P3DX in LabVIEW.
Mr. Moore
(3,031 Views)
(3,028 Views)
