Supported 2.4Ghz wireless protocols in LabView
As part of our university project we're using your Robotics Starter Kit 2.0 and two other Robots from Lynxmotion (Brat & Tri-trak).
Our aim is to integrate all three robots with LabView on a PC using Bluetooth/2.4Ghz Wireless connections.
Our Tri-Trak can be controlled by a PS2 controller which uses a 2.4Ghz wireless connection. I am unsure of the protocol for this, but it doesn't seem to be Bluetooth. Does LabView support 2.4ghz wireless protocols other than Bluetooth?
Any advice or feedback would be greatly appreciated,
Richard.
(3,135 Views)
Hello Richard,
What do you exactly mean with LabVIEW support for protocols?
The following RF toolkits might be worth taking a look at:
http://www.ni.com/rf/software.htm
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,100 Views)
Accepted by topic author Freemri
ThiCop,
Thanks for your response.
As we were unable to determine what protocol/technology the lynxmotion robot was using, we decided to purchase a bluetooth module for it.
(3,072 Views)
Thanks for letting me know.
Good luck with the further programming!
Kind Regards,
(3,048 Views)
