Supported PLCs by NI OPC Server
Hi all;
Are the following PLCs supported by NI OPC Server:
- Yokogawa CS3000
- Smar 600
Waiting for your valuable reply.
(2,969 Views)
This is what you are looking for:
Supported Device & Driver Plug-in List for NI-OPC Server
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,968 Views)
Thanks for your reply.
One more thing: is it possible to bind shared variables (in the DSC Module) to Tags corresponding to Smar PLCs, through the Smar OPC Server?
(2,949 Views)
Accepted by topic author Tarek_Safwan
Yes, that should be possible. You will need to go to Project Explorer, right-click on My Computer -> New -> I/O Server and choose OPC Client. You will get the attached page, at which point you can select network and choose the machine where the OPC server is based. After you have set this up successfully, you can bind shared variables to the OPC registers.
Adnan Zafar
(2,931 Views)
