Suppress popup listbox
Hi all,
If the text in a lisbox line exceeds listbox width, and you point it with the mouse,the entire text will popup in a yellow frame.
Is there a way to suppress this.
(2,612 Views)
Hello Franzo,
As far as I know there's no way to supress this.
Is there a specific reason why you want to supress it?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,584 Views)
Hi Thierry,
The text I placed in the listbox contains linefeeds(multiline ON, auto sizing row height OFF), for the user only the first line is relevant.
Its pretty annoying when you want to select one or more lines, because the yellow frame hides the others.
I just thought that I missed some property.
So now I am considering a multicolumn listbox putting the first line in the first and the rest in the second column, and showing only the first.
Regards
Frans
(2,581 Views)
Hello Frans,
If it's configured like that, then it can indeed be annorying.
Just out of curiosity:
What is the functionality/goal of the listbox in this application?
Maybe there are other thing I can point you towards (depending on the application).
Kind Regards,
(2,563 Views)
