Surveillance camera using USB Webcam
oh..i c...
Labview makes life so easy...
thank you for your help agian
Krispiekream
Message 31 of 43
(5,698 Views)
hi kristen, sorry...again..
i created an example of 1 file image for OCR from the example you give me.
I think I implemented it.
I was not able to decode the object. i got an ??L7?????????
do you know why?
Krispiekream
Message 32 of 43
(5,685 Views)
Hi krispiekream,
Make sure the green ROI is accurate.  Also, it might help to use the OCR Training Interface to help the OCR algorithm learn the characters better.  The OCR Training Interface can be found by going to Start >> Programs >> National Instruments >> Vision >> OCR Training.  I hope this helps!
Kristen H.
Message 33 of 43
(5,668 Views)
Hi
              I have made a PC controlled RF robot operated at 434 Mhz using parallel port. The circuit having only four channels in order to control two motors in both direction. But now I want to attach a camera in the robot which acts as eyes for my robot and my robot can see the enviorment and transfer exactly to the labview wirelessly and so that I can choose the best path for its movement.
So please suggest me where to began i.e type of camera required and how should it be programmed.
Thanks in Advance.
Regards
Gaurav Sharma
Message 34 of 43
(5,659 Views)
Gauruv,
Your question is unrelated to the original thread.  You should post a new message thread with your question.
Message 35 of 43
(5,652 Views)
Hi Kristen, I am back on this project agian..
okay..here is what i have..
I dont know where I did wrong to get that error.
Message Edited by krispiekream on 04-20-2009 04:40 PM
Krispiekream
Message 36 of 43
(5,609 Views)
Hi krispiekream,
I assume you were trying to run the OCR example when this error occured?  Were you able to run it before?   If so, did anything change between being able to run it and the error occuring?  Can you check Measurement & Automation Explorer for LV RunTime Engines?
Kristen H.
Message 37 of 43
(5,591 Views)
no, i am trying to using OCR training and it was missing labview runtime engine.
It is working now. I am trying to get familiar with the OCR training interface.
Thanks!
Krispiekream
Message 38 of 43
(5,583 Views)
Kristen,
the OCR training is very cool.
But just in case my professor asked how did I do it.
Do you know where I can find information on how NI uses the OCR algorithm?
Krispiekream
Message 39 of 43
(5,580 Views)
Hi krispiekream!
The best documentation on the algorithms (or as close as we can get since its proprietary) will be in the Vision Concepts Manual.  You can find it by going to Start >> Programs >>National Instruments >>Vision >> Documentation >> NI-Vision >>Vision Concepts Manual.  Check that out!
Kristen H.
Message 40 of 43
(5,551 Views)
