Swap DC and ground voltages of Keithley 2400 meter
Hi
I am using Keithley 2400 source meter to apply voltage to my chip. The test that I am performing
has the following requirements:
In the first stage, I apply DC voltage (from source meter) on one pad (Pad-A) of the chip and ground
(from source meter) on the other pad (Pad - B) and take some capacitance measurements.
In the second stage, I need to swap these voltages i.e. DC voltage to Pad-B and ground to Pad-A.
I am already using a labview code to apply the voltage and make the capacitance measurements.
Is it possible by any chance that I can control the swapping with the labview code automatically,
without having to swap them manually?
Thank you for the help
(3,029 Views)
Hi funny fox,
It will depend on your instrument drivers, but you should be able to do this by adding some extra logic in LabVIEW. You can use a case structure, or even an event structure if you want the user to be able to swap them.
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(2,999 Views)
Dear Efrain,
Thanks a lot for the response. The drivers I am using are directly downloaded from NI using
labview driver search feature (Keithley 24xx drivers).
Can you please provide me some more details on the logic you were referring to ? I mean
some reference that I can look into or some possible examples.
Thank you
(2,989 Views)
Is it important to switch the GROUND?
Or do you only need to switch the polarity of the voltage between your pads?
Sometimes it makes a BIG difference 😉
Greetings from Germany
Henrik
LV since v3.1
(2,980 Views)
