Swapping x and y axis in intensity graph
Hello everyone,
I'm an intern in company that just started using LabView. Unfortunately there is no one I can ask about programming in it right now. I hope you could help me. I was told to show power spectrum of radio signal on intensity graph. My problem is that I should have time on y axis. Oldest time should be on the bottom and newest on the top of the graph. X axis is supposed to be frequency and Z axis of course power. I have read several post about this problem, but all of them where quite old so I hope that something has changed since then. I know I could swap axis using XY graph. But according to my knowledge I wouldn't have Z axis then. I have seen waterfall graph as well which I think should be perfect because my boss is calling what I should do a waterfall, but he says that it is not what he wants to get. I'm using LabView 2015 sp 1 32 bit with NI USRP-2954R. If anyone would like to see my problem I will add my simplified program.
Thanks in advance 🙂
(8,295 Views)
Hi Kirssika,
to swap axis on a intensity graph you need to transpose the Z array…
(8,278 Views)
Your data is a 2-D array where X and Y are each dimension of the array, and the Z value is the value of the element in that array.  To swap X and Y, just use Transpose 2-D Array
In your situation, the 2-D array is just built from a 1-D array so you basically have a single row with X columns.  Transposing will give you a single column of X rows.  I don't know how well that shows up on your intensity graph.
EDIT:  Also be sure to use Block Diagram Cleanup on your VI.  You have a lot of overlapping wires and wires running backwards unnecessarily.
(8,274 Views)
Thanks for your replay! I have tried adding transpose array into my project. But I got really weird effect. My frequency is on the x axis as I wanted but it increases as it were time. Time on the other hand is on y axis and is from -250k to 250k. Z axis I think should be alright but it is shifted and I can see it only if I use hand tool from graph palette. I will try working on it. You gave me a big push ahead anyway. If you come with any idea I would be greatfull if you could share it with me.
Could you please tell me more about block diagram cleaning? For now I have been doing this manually or with clean up wire.
(8,239 Views)
Accepted by topic author Kirssika
I have found my answer here http://208.74.204.114/t5/LabVIEW/Change-direction-swap-axes-of-Intensity-Chart/td-p/3302983. Thanks for guiding me to the right direction.
(8,195 Views)
