Sweep Chart Broken Interpolation Lines for some Interpolation Styles
I made a similar post believing there was an issue with the line style, but it actually appears to be the interpolation style.
When any of the bottom 3 interpolation styles are selected on a chart, the interpolation lines break and have a dashed appearance.
Using the scroll bar on the front panel causes the chart to redraw and display normally for a moment.
The vertical step interpolation displays fine:
Horizontally centered step appears fine:
Linear has breaks, which appear much worse depending on timing of drawing to the chart and frequency of the signal:
Linear again at different timing:
Horizontal step has breaks. I can see faint lines connecting them while it runs, but they disappear when I screenshot it.
and finally vertically centered steps is similar to the previous:
(1,059 Views)
(1,054 Views)
