Sweep IEPE channel setup
I am struggling to configure the channel configuration (specifically the IEPE settings) of the SVT sweep VIs.
The options are AC,DC and ground, which integers represent them? Is there an example or a properly set up constant available anywhere? Thanks!
Attached is a picture of part of the VI.
(2,615 Views)
Hi Timo
The integers  for AC is 10045, DC is 10050 and grnd is 10066.  I am attaching a  picture where u can find these integers for  the options.
As far as example for configuring SVT sweep VI you can get a VI called SVXMPL_getting started with swept sine.vi (DAQmx) in Find examples
Search for Sweep and u will get this VI. It explains a lot and is in detail about how you can configure your acquistion. Play with that Vi and you will get what you want from it for your data acquistion.
Nitin
(2,604 Views)
