Switch between 3 specific values on button press
chis20 wrote:
I'm a noob here...do I have to accept a solution from the previous messages?
It would be very nice if you did.  You should mark Altenbach's last post as the solution.
Message 11 of 15
(1,330 Views)
Accepted by topic author chis20
@chis20 wrote:
Smiley Happy Smiley Happy Did it!! Thanks altenbach!! Smiley Happy Also I changed the inner case structure with quotient & remainder - much simpler!
Here is a simple version without event structures. Is it similar to your solution? 😄
Message 12 of 15
(1,322 Views)
Yes, it's very similar! You used some functions that I didn't know they existed Smiley Tongue Other than that thanks for the solution!
Mine is attached below!
Message 13 of 15
(1,304 Views)
One minor point: The constant wired to the lower input of Q&R should be I32. Right-click and chose the representation.
Now all index related calculations are on integers (blue) as they should be.
Message 14 of 15
(1,298 Views)
Got it, thanks!
Message 15 of 15
(1,290 Views)
