Switch case list UI
Hi!
For pedagocial and c-like reasons i'd like there to be a "Case-unbundle", which would be very nice if you're only calling sub-vi's in a case e.g.
Is there any way to create such a thing?
Instead of the Case-square i want it to be a "Unbundle by name" where i connect each output to my sub-vi's (like a multiplexer) and the appropriate one is called.
Any ideas?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,639 Views)
Hi Yamaeda,
do you have a cluster and want to unbundle them? Are this all elements from the same type in your cluster?
Mike
(3,637 Views)
Any ideas?
Do you mean you want to unbundle case by name? Do you want to know which case is connected?
(3,635 Views)
Well, nice asumptions, but i have another one:
LabVIEW has a case structure where only one single case is visible at a time. This is a huge difference to C-based languages where a switch-case displayes every case at the same time in a "list".
I think the question from the OP is: "Is it possible to display a case-structure in LabVIEW 'flattened' so that every case is visible at the same time?"
And to answer this question: No it is currently not possible, was never possible and hopefully will never be. But you can create a "report" using the print-function and this can automatically create screenshots of each case and display them next to each other.....
just my 2cents
Norbert
Norbert
Expert: Geometry
(3,632 Views)
Hi again!
You guys are fast! 🙂
Norbert is the closest, and my original question might have been badly explained.
My idea is something similar to a Flattened Case, yes, but i also want to avoid the whole box/square (to get a cleaner area). Thus it should look like "unbundle by name", but list the cases instead, and only run the appropriate thread.
/Y
Qestit Systems
(3,614 Views)
Hm, you have a good feedback on LV for certain cases, yes.... but as stated before, i hope there will not be changes to the case-structure.
The explanation for this is: Style. You should always keep your blockdiagram (aka uncompiled sourcecode) as clean as possible. If a case-structure would support such a feature (i think that you are up to a feature similar as the expand/collapse function in C#), the code of a mediocre programmer would be getting worse in comparison to now. And to be honest, most codemodules already suck in regard to style, so such a feature would mess up the whole thing to even worse code....
Please note that this is a personal opinion and may differ from other LV-users!
Norbert
Norbert
Expert: Geometry
(3,597 Views)
