Switch focus between numeric controls in different clusters
Hello
I am a newby in labview and i have a question.
I have a user interface with a number a clusters with in each cluster a numeric control and some other controls.
When i enter a barcode in the numeric control of the first cluster and press enter i want to give the numeric control in the second cluster the focus.
What is teh best way to do this in Labvies
thanks in advance
(2,671 Views)
@Tonnie wrote:
Hello
thanks in advance
You need to use an Event Structure.
Look at the included LabVIEW examples.
(2,661 Views)
Hi Tonnie,
You can do this by creating a reference to the control in the second cluster that you want to get Key Focus.
(Right click the control and select Create >> Reference)
When you detect the Value Change in the Numeric control in the first cluster, use the reference you created and a property node to set the Key Focus.
See the attached example.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,654 Views)
