Switch port based on over threshold
does anyone know how to do:
-threshold with setting the value in the graph,
-if the value is larger than the threshold, then it sends the command
I have this program with wave generator and osciloscope and I need to switch the port in the optical switch when the value is higher than the threshold.
Thanks for help and answer. 🙂
(3,298 Views)
Hi Adam,
You could add a cursor to the graph and get the value from the cursor in the graph with a property node (Cursors >> Cursor Position >> Cursor Y) and compare against that.
If your new value is larger than that, trigger your command. Is that what you want?
Sorry, I can't open your VI, so if you have questions, please re-upload it for LV 2015.
Remember Cunningham's Law
(3,270 Views)
My first thought is something like this:
If this would be too time consuming you could have this logic be executed in another loop.
EDIT:
Misread the "setting the value in the graph". The above reply from Peter regarding the graph cursor is a solid idea.
dK
(3,269 Views)
There is old version VI.
(3,250 Views)
Thanks for all.
I have it! 🙂
My theses is saved.
(3,245 Views)
