Switch
I need a switch, which must turn on a led by its
high signal and turn off the led by the next high signal.
How can I create or get that kind of switch.
Thanks.
Message 1 of 15
(12,929 Views)
Hi Tayfun,
One way to solve your problem is to use a standard switch in combination with a while loop and a shift register . The latter then serves as a state memory. I attached an example for LabVIEW version 6.01. I hope this helps.
/Mikael Garcia
Message 2 of 15
(12,926 Views)
how can i modifly this switch so that it switchs state everytime a loop is run?
thanks
Message 3 of 15
(12,781 Views)
A plain shift register and the Not function.
Message Edited by Dennis Knutson on 04-30-2007 09:44 PM
Message 4 of 15
(12,774 Views)
Do you know how I can modify the timed switch so that instead of switching on and off repeatedly, the switch turns on and remains on for a user-defined period of time, then switches off and remains off for the same amount of time, and so on? (On a chart a square wave would appear, although generating a square wave is not my objective) Thanks
Message 5 of 15
(12,674 Views)
Hi fireandfury,
Thanks for contacting National Instruments.  If I understand your question right, it sounds like you want a switch that will turn on and off for set periods of time programmatically.  It looks like the simplest way to do this may be to use a flat sequence structure that has wait timers in each sequence when the state of the switch is altered.  The attached image below should give you a good idea of how I did this and hopefully it will help you out.  As you can see, the boolean LED is only in the on or off states for 250ms at a time.  I hope this helps and if you have any more questions feel free to reply back. Thanks!
Noah R.
Message Edited by Noah R on 09-26-2007 04:22 PM
Regards
Noah R
Applications Engineering
Message 6 of 15
(12,641 Views)
Thanks!
Is there a way to do it with a stacked sequence structure? I am using LV6, which i don't believe supports flat sequence structures.
Also, will this VI generate a square wave as opposed to a triangle wave (my ultimate objective)?
Message 7 of 15
(12,613 Views)
If your ultimate objective is a triangle wave, then you shouldn't even be thinking about using a Boolean. A Boolean has exactly two states - on or off. Maybe if you stated your ultimate objective more clearly and what you need to do with a triangle wave? LabVIEW does have a built-in Triangle Wave Generator function.
Message 8 of 15
(12,610 Views)
Hi fireandfury,
Using a stacked sequence structure shouldn't be a problem.  The only difference will be to make each frame of the flat sequence structure that I posted above its own layer on the stacked sequence structure.  This way, it will follow the same sequence that I have shown above. Let me know how it works.  Thanks!
Noah R.
Regards
Noah R
Message 9 of 15
(12,588 Views)
Is it possible to create a toggle switch which is automatically turned off after one iteration of a while loop and stays off until the user switches it back on?
Message 10 of 15
(9,797 Views)
