Switching between loops based on elapsed time.
Yeah I created the enum and connected it to shift register but how do i switch between the values of enum after the time intervals?
Message 11 of 25
(3,273 Views)
can you show us what you have?
Message 12 of 25
(3,270 Views)
Hi
I don't exactly have anything except for a while loop with an enum attached to a shift register and case structures inside the while loop. I can attach it here but it would be rather embarassing. I'll try to develop something worthwhile today and then post it. I need to understand to work with the elemnets of state machine.
Message 13 of 25
(3,251 Views)
@kunal7505 wrote:
Hi
It's not embarrassing; it's encouraging!  Just let it all hang out, like we're your doctor.  We won't be too judgemental.  😄
Bill
CLD
(Mid-Level minion.)
Message 14 of 25
(3,241 Views)
Accepted by topic author kunal7505
See if this rings a bell. (Very generic code!)
Message 15 of 25
(3,235 Views)
Here is what I have been able to setup. It's working pretty well but I still need some advice. Throughout the vi I have added comments wherever I am not clear. The major part is how to check for the 30 minute time interval. Another thing that is happening is that the when I switch to backwash valve the feed valve timer keeps on running, but I cannot pause it as well since I keep track of the one minute time for backwash using that timer. Please suggest resolve for the same and also if other tweakings are suggested.
Message 16 of 25
(3,219 Views)
as a first step, get rid of all these local variables. none are needed. Place the indicators after the case structure and feed relevant values out of the case structure. Also place the controls outside the case.
Have you studied my examples.
Message 17 of 25
(3,209 Views)
try ranging, leds are on at the top of the hour as initial start or you can start by adding 30 minutes to the existing system clock minutes
Message 18 of 25
(3,198 Views)
@altenbach
Can you please explain the example and as to how it can solve my problem.
Message 19 of 25
(3,165 Views)
Do you have any specific question?
Message 20 of 25
(3,158 Views)
