07-07-2006 07:07 AM
07-10-2006 07:21 AM
07-12-2006 10:50 AM
01-22-2008 11:10 AM
Hello Everyone,
I am attempting a similar configuration and am hoping to get some help. I am currently using a PCI-6601 counter with an optical encoder to trigger a PCI-6122 multifunction DAQ via the RTSI bus. Now, I have two PCI-5112 boards that I would also like to trigger the same way. I am stumped though because when I configure the devices in MAX, the 6601 shows up as a DAQmx device and the 5112 shows up as a Traditional DAQ device, and I cannot connect the two devices to the RTSI configuration that I have set up between the 6601 and the 6122.
Can I still use the import and export VIs to set up the triggers for the 5112 without configuring the RTSI connection in MAX, or is there a way to get MAX to recognize the 5112 as a DAQmx device?
Thanks in advance,
Ryan
