Synchronise PXIe-6363, PXIe-4357 and PXI-4462
Hi all,
I'm building a PXI system using a 1078 PXIe chassis and i wanted to get a bit of advice on synchronising the above mentioned cards.
Is it possible to use the structure outlined in this article http://zone.ni.com/devzone/cda/epd/p/id/5299, instead of the M series card using a X series and with the addition of the PXIe-4357? Also, is ok to use different sampling rates as long as the blocks are the same for each device?
Chris
(2,278 Views)
Having reassessed my requirements, I've realised that synchronising these cards is not required.
(2,265 Views)
