Synchronising Wind Speed data and Real-time from computer
I need help to display the wind speed data on the wind speed gauge with the same time in the text and the real-time from computer.
For example:
in text : 12:32:30 AM 0.38 1.14
i would like to display 0.38 in wind speed gauge based on the same time with the real-time from computer, not from the time in text.
I've attached the program i made so far.
I REALLY NEED HELP
thx 🙂
in the 2nd column in text is wind speed, 3rd column is gust speed
(2,585 Views)
See here  Time to xl  (converts time from the LabVIEW scale and epoch to the scale and epoch used by Excel.  you do have to manually set the cell formating to time/date in ecxel to view the number as YYYY/MM/DD HH:MM:SS format
Don't forget to kudos the idea here
(2,529 Views)
