Synchronization S-Series M-Series via DAQmx
Dear engineers,
I own PXI-6251 and PXI-6120 and try to couple them together, that one ai-channel of the M-Card follows exactly 4 ai-Channels of the S-Card at the same time and samplingrate.
So I want to get a 5-AD-Channel-System.  The S-Card should be the Master and the Slave should sync itself on the same sample rate and starttrigger.
I found an example for E-Series-M-Series Synchronization but coudn't set a DelayFromSamplCLk in Ticks-  only "TriggerStartVerzögerung" instead.
Another problem is, that i could not pretrigger both cards at the same time. I used the ai/ReferenceTrigger for the M-Card but there seem to be no fix delay between both cards.
1.How big is the SampleClockDelay between S- and M-Series during digital triggering and how can it be set?
2.How big is the Pretrigger-Delay during analog-triggering and how can it be set?
Thanks for help.
Message 1 of 1
(2,382 Views)
