Synchronization between PXI NI SCOPE (5154) and USB DAQ (6216) with an external clock/Trigger
I trying to acquire Analog signals using NI PXI SCOPE at 200 MHz (only first 9000 samples, triggered every 2ms) and a USB DAQ (1 sample each at 2ms) using an external clock (at 500Hz) based DAQmx acquisition for USB DAQ, and the same clock (500Hz) as the trigger for NI SCOPE card.
Please share some references to implement this topology correctly, so that synchronised data can be recorded with both modules.
(1,143 Views)
Hi  rahul_manoj
Dis you check this article before?
There you can find well explained Synchronization concepts, try to go through that article.
Regards
(1,017 Views)
