Synchronize Analog Input and Output in PCI 6259 example Error
I have a PCI 6259.
I program example Figure 2 in http://www.ni.com/white-paper/3615/en/#toc3  to syncronize analog input and output.
But I recived this error:Error -89120
Possible reason(s):
Source terminal to be routed could not be found on the device.
Make sure the terminal name is valid for the specified device. Refer to Measurement & Automation Explorer for valid terminal names.
Property: Start.DigEdge.Src
Property: Start.DigEdge.Edge
Source Device: Dev1
Source Terminal: ai/Start Trigger
Task Name: _unnamedTask<52>
would you please help me for this problem
(2,549 Views)
There is no space in Start Trigger.  It should be ai/StartTrigger.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,544 Views)
