Synchronize Scrollbars or Indexing
Hi there,
I have a problem in an aplication I'm developing. I have two diferent arrays. I would that if one row or column index change in one of them, the other behaves same way, so you have both everytime at the same position. Anybody knows how to do it? Can it be done with scrollbars?
Thank to anybody for helping
(3,440 Views)
@rroa wrote:
Hi there,
The most simple thing would be to display both arrays in a table.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,434 Views)
Hi all,
I dont really understand what do you mean with that question, can you explain a bit more or introduce an exact vi explaining what is your real problem?
Jaime Cabrera
NI Applications Engineering
Jaime Cabrera
NI Applications Engineering Spain
(3,417 Views)
This question has already been answered ....
you can use the property nodes to sync the index
and you can customize your array index to a slider (with a trick.. search the forum)
Sorry, out of time to search myself
Greetings from Germany
Henrik
LV since v3.1
(3,414 Views)
